mapserver 4.2.2 compile problem on redhat as3
Aaron Steele
asteele at BERKELEY.EDU
Fri Aug 13 16:27:26 EDT 2004
hi daryl,
the gdal flag was the culprit. the following change to my configure
invocation was the fix:
--with-gdal=/usr/local/bin/gdal-config
mapserver now compiles! : )
here is the report from /usr/local/bin/gdal-config:
> /usr/local/bin/gdal-config --libs
> -L/usr/local/lib -lgdal
is this at all interesting?
thanks again,
aaron
On Aug 13, 2004, at 1:11 PM, Daryl Herzmann wrote:
> howdy,
> On Fri, 13 Aug 2004, Aaron Steele wrote:
>> my gdal install procedure (if suspicious, what is a more appropriate
>> location...):
>> in /usr/local/gdal-1.2.1/
>>> ./configure
>>> make
>>> make install
> The make install then installed the libraries and what not in
> /usr/local
> and not /usr/local/gdal-1.2.1 , so your mapserver flag should be
> Does /usr/local/bin/gdal-config work? If so, what does this report?
> daryl
> * Daryl Herzmann (akrherz at iastate.edu)
> * Program Assistant -- Iowa Environmental Mesonet
> * http://mesonet.agron.iastate.edu
