projection trouble - Michigan GeoRef
Dylan Keon
keon at NACSE.ORG
Mon Aug 16 12:07:33 EDT 2004
I'm trying to use a layer that's projected in the "Michigan GeoRef"
projection, but I can't get it to line up with other data. I'm using
the projection parameters provided by the state of Michigan
(http://www.michigan.gov/documents/DNR_Map_Proj_and_MI_Georef_Info_20889_7.pdf).
Here's what I get when trying to line up a Michigan layer (GeoRef
projection) with a national 24k quad index (geographic), putting
everything into geographic for now:
http://gis.nacse.org/mstemp/109267161738211.png
I haven't found examples of this online, and wonder if I messed up a
PROJ definition or something. Thanks for any help. Mapfile is below.
--Dylan
NAME 'test'
SIZE 640 480
STATUS ON
EXTENT -126 34 -66 46
UNITS DD
IMAGETYPE png
WEB
IMAGEPATH '/www/temp/'
IMAGEURL '/temp/'
END
PROJECTION
'init=epsg:4326' #latlon
END
LAYER
NAME 'quad_index'
DATA '/gis/data/us/24kgrid.shp'
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR -1 -1 -1
OUTLINECOLOR 0 0 255
END
PROJECTION
END
END
LAYER
NAME 'ecoregions'
DATA '/gis/data/mi/ecoreg100'
STATUS DEFAULT
TYPE POLYGON
CLASS #simple for now
COLOR 198 123 48
END
PROJECTION #NAD 1983 Michigan GeoRef Meters <102123>
'proj=omerc'
'k_0=0.9996'
'lat_0=45.30916666666666'
'alpha=337.255555555556'
'lonc=-86'
#'x_0=2546731.496' # PROJ
#'y_0=-4354009.816' # manual
#'ellps=GRS80' # says these are not
#'datum=NAD83' # needed for oblique mercator,
#'units=m' # but I tried them too,
#'no_defs' # in various combinations
END
END
END
