Couple of questions on MapScript and the Map File
Huey Brantley
huey.brantley at VANDERBILT.EDU
Mon Aug 16 13:03:21 EDT 2004
No. Sean's reply was the answer I was looking for.
/Answer to 1 is yes, for the SWIG and PHP mapscripts, version 4.3 (in
CVS only).
You never asked the question so directly on IRC this morning. :)
Sean /
Huey
Lowell Filak wrote:
>There is an angle member for the label object but it will not rotate the
>entire map.
>Is that what your looking for?
>Lowell
>The following message was sent by Huey Brantley
><huey.brantley at VANDERBILT.EDU> on Fri, 13 Aug 2004 14:48:27 -0500.
>>1) Is there a way to apply a rotation to the map with mapscript? I have
>>found references to a "ANGLE" member but I don't think mapscript
>>supports it.
>>2) Can you label using multiple fields from a data source? I'd like to
>>concatenate two or more fields to form the label.
>>Thanks,
>>Huey Brantley
>>Vanderbilt University
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040816/6a2f4018/attachment.html
