Couple of questions on MapScript and the Map File
Lowell Filak
lfilak at MEDINACO.ORG
Mon Aug 16 12:41:45 EDT 2004
There is an angle member for the label object but it will not rotate the
entire map.
Is that what your looking for?
Lowell
The following message was sent by Huey Brantley
<huey.brantley at VANDERBILT.EDU> on Fri, 13 Aug 2004 14:48:27 -0500.
> 1) Is there a way to apply a rotation to the map with mapscript? I have
> found references to a "ANGLE" member but I don't think mapscript
> supports it.
> 2) Can you label using multiple fields from a data source? I'd like to
> concatenate two or more fields to form the label.
> Thanks,
> Huey Brantley
> Vanderbilt University
