Feature Object and text
Sean Gillies
sgillies at FRII.COM
Mon Aug 16 13:44:14 EDT 2004
On Aug 16, 2004, at 11:17 AM, Stefanie Weykam wrote:
> Hi all,
> I have an annotation layer, it contains a point (feature) and a string
> to
> label this point.
> Actually, the string is the title of the map and I want to change it
> according to the currently displayed theme.
> Is there any feature object which can be set by MapScript? The Class
> Reference doesn't mention any. And, how do I change the color of the
> label?
> I always get error messages saying that the property (both color and
> text)
> don't exist or that the function setRGB() is undefined....???
> Which objects do have these properties - do I nedd colorObjects?
> styleObjects?? How do I create them?
> Thanks,
> Stefanie
> LAYER
> NAME "subtit"
> STATUS ON
> TRANSFORM FALSE
> TYPE ANNOTATION
> FEATURE
> POINTS 635 10 END
> TEXT "Species Richness" # "a species name"
> END
> CLASS
> LABEL
> TYPE TRUETYPE
> FONT verdana # verdana-italic
> SIZE 12
> POSITION LL
> COLOR 80 130 0 # 160 90 0
> END
> END
> END
Stephanie,
Support for inline features is currently limited. You cannot
access a feature once it is in the feature "set".
The thing to do is to leave out the FEATURE block in your map
file, and insert a new feature as needed:
p = mapscript.pointObj(635, 10) # the point
s = mapscript.shapeObj(layer.type) # new shape to hold point
l = mapscript.lineObj() # point must be in a line
l.add(p) # add point to line
s.add(l) # add line to shape
s.text = 'Species Richness' # label for point
layer.addFeature(s)
layer.draw(map, image)
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
