Support for ArcZ in shapelib?
Eduardo Spremolla
edspremolla at ANTEL.COM.UY
Wed Aug 18 08:07:32 EDT 2004
A much utile way may be map Z and M as dbf fields. That way can be used
as labels, querys and filters.
LALO
El mar, 17-08-2004 a las 17:26, Frank Warmerdam escribió:
> Chris Helm wrote:
> > Hey list-
> > I just wanted to see if they were any plans for
> > providing support for "ArcZ" shapefiles. We recently
> > had a few cross our paths and were able to work around
> > the problem when we found out Mapserver and shapelib
> > doesnt handle them. But just for our knowledge we
> > wanted to ask why the format is not supported?
> Chris,
> I think this was already recently answered here on the list. The short answer
> is that Shapelib supports ArcZ files just fine, and you can use them with
> MapServer through OGR. However, the high efficiency version of shapelib
> that was integrated into MapServer some time ago does not included support for
> 3D or 4D shapefiles. It could be implemented fairly easily if someone was
> sufficiently motivated (assume we just want to discard the Z or M values).
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
Eduardo Spremolla <edspremolla at antel.com.uy>
Antel I+D
