Problem compiling Mapserver
Howard Butler
hobu at IASTATE.EDU
Wed Aug 18 10:39:11 EDT 2004
The binaries are back up. I updated my zope instance to use the latest,
and I had some trouble bringing one of the libraries that support file
system views along with it.
Get your copy of the freshest CVS Windows Python mapscript available at
http://hobu.stat.iastate.edu/mapserver/build_output
Howard
At 09:07 AM 8/18/2004, Sean Gillies wrote:
>Howard Butler's binary site appears to be temporarily offline but
>should be back soon. His 4.3 binaries will work fine with the
>latest 0.7.6 release of zmapserver.
>cheers,
>Sean
>On Aug 18, 2004, at 7:38 AM, Michael Schulz wrote:
> > Welcome Etienne,
> > I assume you want to start using mapserver/python/zmapserver on=20
> > windows since you mention a dos
> > command bar, is that right? I would suggest using precompiled binaries=20=
> > instead of compiling
> > everything on your own.
> > Have a look at=20
> > http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PythonMapScript
> > there you will find links where to download precompiled=20
> > python/mapscript binaries ("External
> > Links"). You will need one of these (depending on your requirements,=20=
> > with oraclespatial, etc.) to
> > use zmapserver.
> > Be careful to choose packages that use the same python version, e.g.=20=
> > if you use zope2.7 this will
> > mean you have to use python2.3 and accordingly choose the=20
> > mapscript/python build.
> > After you have installed the python/mapscript binary you can start=20
> > using mapscript in a python shell
> > and you can use zmapserver with zope.
> > HTH, Michael
> > Etienne Desgagn=E9 schrieb:
> >> Hi everyone, I'm new here and I have problem to start compiling=20
> >> mapserver. I
> >> have download and install Python and Mapserver and I just want to=20
> >> compile
> >> mapserver. It's problably funny (I must begin somewhere...) but I=20
> >> don't know
> >> where to type the ./configure --with... . In a dos command bar? My=20
> >> project
> >> is to install Plone/Zope and ZmapServer after that.
> >> Thanks!
> >> Etienne.
> > Michael Schulz in medias res
> > Dipl.-Geologe Gesellschaft f=FCr
> > Informationstechnologie mbH
> > In den Weihermatten 66
> > 79108 Freiburg
> > 0761 55695-95 (Fax 96)
> > mschulz at webgis.de www.webgis.de/www.zopecms.de
