javaMapscript compilation
Stéphane RIFF
stephane.riff at CERENE.FR
Wed Aug 18 08:44:49 EDT 2004
Hello,
I try to compile javaMapscript, i followed the instruction on yhe
WikkiMapserver but i can't get it work.
First, when i want to run make in the "mapscript/java" directory, the
"Makefile" ask for mapscript.i and mapscript_wrap.c
which are in "mapscript" directory... So i copy them in "java" but is it
a good solution ???
If we forgot this error :) , ican get mapscipt.jar and libmapscript.so.
But when i try to execute the test program it complain about new_mapObj,
here is the error :
Exception in threa "main" java.lang.UnsatifiedLinkError: new_mapObj
at edu.umn.gis.mapscript.mapscriptJNI.new_mapObj(Native Method)
at edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:330)
at myFirstMap.main(myFirstMap.java:11)
Here is the java program :
import java.io.*;
import edu.umn.gis.mapscript.*;
public class myFirstMap {
public static void main(String[] args) throws IOException {
System.loadLibrary("mapscript");
mapObj map;
imageObj image;
map=new mapObj("mapfile.map");
image=mapa.draw();
image.save("yuhuu.png",map);
If someone could help me, i can't find out what is going wrong.
Thanks
