javaMapscript compilation
Frank Rittinger
gis at SCHNEGG.NET
Mon Aug 23 03:56:03 EDT 2004
On Wednesday 18 August 2004 14:44, Stéphane RIFF wrote:
> Exception in threa "main" java.lang.UnsatifiedLinkError: new_mapObj
> at edu.umn.gis.mapscript.mapscriptJNI.new_mapObj(Native Method)
> at edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:330)
> at myFirstMap.main(myFirstMap.java:11)
Hello Stephane,
this sounds like your linker can't find the libmapscript.so library. After
compilation, you have to set up your linker in order to use the new library.
I think you can put it in some standard location, e.g. /usr/local/lib and run
ldconfig again. I'm not sure about the right command parameters.
Regards, Frank
Frank Rittinger
TERRAPLAN Geographische Informationssysteme
Gewerbestr. 33
79227 Schallstadt
Germany
Tel.: 07664-505315
Fax.: 07664-505321
http://www.terraplan.com
