FW: What's Wrong With This Picture?
Pagurek, Debbie
PAGUREKD at AGR.GC.CA
Wed Aug 18 11:08:45 EDT 2004
It's best to keep copying the MapServer list - someone there might have
the answer.
Is your server available to the public? I can't seem to see it given the
URL you are using. Sid - is that sid.net or sid.org?
You should also be able to view your map using mapserver CGI - e.g.
using ?map=/var/www/aviano/aviano.map&mode=map&layer=Aviano1
I think there might still be something strange with your imageurl - what
does the server expect to see to point to the location of images? I
don't think it would be http://sid/var/www/aviano/tmp/ as you have
specified. But then again, I'm not sure if that imageurl parameter is
important if using wms requests or mode=map. It might only be used when
you specify mode=browse - can someone out there clarify this?
The only other thing I can suggest is to send someone your raster image
to see if they can get it working on their machine.
Can anyone else on the list comment on this issue? I still have a
feeling that this is either a problem with extents or projection or
something in the mapfile.
Debbie
-----Original Message-----
Sent: Wednesday, August 18, 2004 10:41 AM
To: Pagurek, Debbie
Subject: Re: What's Wrong With This Picture?
Hi Debbie,
Thanks so much for all of your help. The sample map file was a great
help toward a better understanding. I'm still getting a blank, so I
think you're probably right about me not providing enough information in
my URL. I was just going by the information in the WMS Server How-To,
but I still don't completely understand what I'm doing. This is the URL
I'm using:
http://sid/cgi-bin/mapserv?map=/var/www/aviano/aviano.map&VERSION=1.1.1&
REQUEST=GetMap&LAYERS=Aviano1
Can you suggest other parameters that might help? Attached is the
current map file. I very much appreciate you taking the time to push me
over this bump in the learning curve.
Barbara
Pagurek, Debbie wrote:
>---------------------- Information from the mail header
>Sender: UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU>
>Poster: "Pagurek, Debbie" <PAGUREKD at AGR.GC.CA>
>Hi Barbara,
>A question:
>What URL are you using to try to show your map?
>You might be missing a couple of things at the top of your mapfile,
such
>as UNITS
>And in your WEB section, you might need IMAGEPATH and IMAGEURL.
>In your layer definition, you could try to put the epsg part of=20
>"wms_srs" "epsg:32633" in capital letters. Seems strange, but I seem
to
>recall reading something about that.=20
>I will send you a couple of mapfiles that you can compare yours to.
>Keep trying - I think you're getting closer to succeeding!
>Debbie
