Zoom to Extent code
Ryan, Adam
ARyan at CO.LINN.OR.US
Wed Aug 18 16:08:07 EDT 2004
Chris,
The parameters [imgbox] and [imgext] are used for navigating with an
existing image. [imgxy] is usually used with [scale]. If you know the
extent you want, just use the [mapext] parameter and leave the rest out.
Read through the CGI help page to see the rest.
http://mapserver.gis.umn.edu/doc42/cgi-reference.html
Hope it helps,
Adam
-----Original Message-----
Sent: Wednesday, August 18, 2004 12:32 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Zoom to Extent code
I just finished digging through the archives (to no
avail) for an answer on how I can go about zooming to
a region using the standard CGI functions.
If someone could provide me some javascript code that
would make it possible to zoom to a certain extent
from a <select> drop down, I would be very thankful.
So far my code looks like:
function zoomTO(){
document.mapserv.imgext.value =
"document.mapserv.ViewRegion.options[document.mapserv.VeiwRegion.selectedInd
ex].value"
document.mapserv.imgbox.value = "-1 -1 -1 -1"; document.mapserv.imgxy.value
= "[center]"; document.mapserv.submit();
and the html:
<select name="ViewRegion" onChange="zoomTO()">
<option value="-19279421.034355 4334895.604301
-13530100.437058 9215380.487355"> </option> Alaska
and so.......
When I try and change the select menu an error says
there are not enough arguments for imgext.
Thank you
Chris
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
