GDAL-DSDK4-pursuits
Swaminathan, Gayathri
gayathri at OU.EDU
Thu Aug 19 09:58:48 EDT 2004
Hi Mighty List!
Thought should share my GDAL/MrSID-DSDK4.0 VC6 compile procedures with the list just incase if it comes handy to someone.
So, I heard Mr.SID DSDK4.0 is free now...at developer.lizardtech.com and decided to try the GDAL with DSDK4.0 compile for windows.
I got GDAL 1.2.1 and DSDK4.0, did the usual GDAL recommendations and hit make!
It threw the error of not finding a file in the GDAL source directory for which the solution recommended by Brent seems to work fine...
Brent's solution URL: http://xserve.flids.com/pipermail/gdal-dev/2004-August/006776.html
So, after that I had to register the "lti_dsdk_dll.dll" and the newly built "gdal12.dll"
According to Andrey the MrSID driver developer., there is also a major bug fixed regarding image handling in gdal-cvs...and he recommends using "gdal-cvs" for the build.
Works like a charm if you follow the above steps.
Gayathri
