problem with annotation display
K. Lessing
umn at KARSTEN-LESSING.DE
Thu Aug 19 14:22:47 EDT 2004
Hi List,
it looks like that I have a problem with my font file - I´m not sure.
I am running MS 4.2.2 on SUSE9.1 with Apache2.
MS is running with freetype Support
Fr labeling some Vectorlayer I downloaded the whole 4.0 tutorial from:
http://terrasip.gis.umn.edu/projects/tutorial/
and installed all font files and the font.list file under:
/srv/www/htdocs/fonts/
The sourcecode of the Mapfile:
MAP
NAME SoSo
SHAPEPATH "../daten"
EXTENT 22 -33 30.5 -34
STATUS ON
SIZE 670 670
UNITS kilometers
FONTSET "/srv/www/htdocs/fonts/fonts.list"
WEB
TEMPLATE "../docs/erstes_template.html"
IMAGEPATH "/srv/www/htdocs/tmp/"
IMAGEURL "/tmp/"
MAXSCALE 800000
MINSCALE 10000
END
LAYER
NAME "vegetation"
DATA "vege"
STATUS DEFAULT
TYPE polygon
CLASSITEM "VELD"
CLASS
EXPRESSION "Afromontane Forest"
COLOR 250 45 67
END
CLASS
EXPRESSION "Dry Sandy Highveld Grassland"
COLOR 25 250 67
END
CLASS
EXPRESSION "Afro Mountain Grassland"
COLOR 0 230 30
END
# .... (25 more Classes are following ...)
END
LAYER
NAME "beschriftungen"
STATUS DEFAULT
FORCE TRUE
TYPE ANNOTATION
DATA "vege"
CLASSITEM "VELD"
LABELITEM "Afromontane Forest"
CLASS
LABEL
TYPE TRUETYPE
FONT "times"
SIZE 20
COLOR 10 10 10
OUTLINECOLOR 255 255 255
END
END
END
END
The result is following message:
msDBFGetItemIndex(): DBASE file error. Item 'Afromontane Forest' not found.
The funny thing is: Without the ANNOTATION Layer everything works fine -
then all Layers are visible ...
(what might mean that the .dbf file can be read therefore - isn`t it?)
I already:
- chanced in the .dbf file each entry in each each cell up to a max.
length of ten characters
- renamed the file name to fonts.txt
- switched of MAX- and MINSCALE and UNITS off
- and fiddled around a lot with the quotation marks and upper and lower
case ...
..nothing helped so far :(
Does have anybody an an advice for me?
Karsten
