Cannot access WMS clients
Howard Mark
MHoward at SPACEIMAGING.COM
Thu Aug 19 15:42:05 EDT 2004
One day my applications worked fine. The next they quit. I narrowed the problem down to the WMS layers in the map file e.g.:
LAYER
NAME onempromo
TYPE RASTER
STATUS ON
CONNECTIONTYPE WMS
CONNECTION http://someserver/cubeserv.cgi?&VERSION=1.1.0&LAYERS=PROMODATA&FORMAT=PNG&TRANSPARENT=TRUE
PROJECTION
"init=epsg:4326"
END
CLASS
NAME "Promo Imagery"
END
END
Local layers (shapefiles) displayed fine. However when a WMS layer was selected, the connection would time out. On the same machine, I can access the WMS layer fine using the URL in IE.
I believe I've isolated the problem to be a patch to IIS, IE or some other security update. We run auto updates here and some don't take effect until a reboot.
I booted my machine the morning that I noticed the problem. To complicate matters, our IT folks just installed a new proxy server. My mapserver is (was) 3.6 running on W2K SP4.
To eliminate the proxy issue, I tried accessing a local WMS layer and had the same problem. I thought I'd update to mapserver 4.2 to see if the problem is fixed there.
Now I get a return when a WMS layer is enabled. However, the response image is not displayed in the map. The timing of the request leads me to believe that I'm getting a response from the WMS server.
Any ideas?
Mark
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
