Cannot access WMS clients
Howard Mark
MHoward at SPACEIMAGING.COM
Thu Aug 19 16:50:29 EDT 2004
A bit of an update on this problem.
I changed the IIS user and of course the permissions changed so that I had a problem reading the TT fonts.
Now when I do a request I can see that I have a problem connecting to the WMS layers (see below).
The difference in 4.2 and 3.6 must be that 3.6 waits for a connection and 4.2 returns sooner.
Interesting that if I don't get the 'hotels' error - then there is no error message returned for the WMS call!
Mark
msDrawMap(): Image handling error. Failed to draw layer named 'hotels'.
msGetCharacterSize(): TrueType Font error. Could not find/open font
msDrawWMSLayerLow(): WMS server error. WMS GetMap request failed for layer 'onempromo' (Status -7: Failed connect to joe:80, errno: 0).
msHTTPExecuteRequests(): HTTP request error. HTTP: request failed with curl error code 7 (Failed connect to joe:80, errno: 0) for http://joe/scripts/mapserv.exe?layers=poi&map=%2FInetpub%2Fscripts%2Ftravel.map&request=MAP&VERSION=1.1.0&FORMAT=PNG&REQUEST=GetMap&HEIGHT=400&SRS=EPSG:4326&WIDTH=500&BBOX=%2D0%2E074080%2C51%2E449956%2C0%2E044298%2C51%2E544546&EXCEPTIONS=application/vnd.ogc.se_inimage
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Howard Mark
Sent: Thursday, August 19, 2004 1:42 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Cannot access WMS clients
One day my applications worked fine. The next they quit. I narrowed the problem down to the WMS layers in the map file e.g.:
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
