I would appreciate any help I can get on getting this map to
work...
Reuven Levitt
reuven at LEVITT.NET
Fri Aug 20 08:50:32 EDT 2004
Hi Everyone,
I am new to the list.
I just started working on a project, and as the first
order of business I need to get mapserver up and
running (which I have done). However I tried to get
my own thing working (Spend a lot of hours reading),
and I am still having some trouble.
This is actually one of the demos, so it should work,
but by image is coming back blank white.
Here is the map file (reuven.map):
MAP
NAME REUVEN
STATUS ON
IMAGETYPE PNG
SIZE 800 500
SHAPEPATH
"E:/Dev/Tools/mapserver/workshop/reuven/data/"
EXTENT -6086744.000 -2784127 4278894 4485901
UNITS METERS
PROJECTION "proj=laea" "lat_0=45" "lon_0=-100"
"ellps=GRS80" "datum=NAD83" END
WEB
IMAGEPATH "E:/Dev/Source/web/workshop/tmp/"
IMAGEURL "/workshop/tmp/"
TEMPLATE "reuven.html"
END
LAYER
NAME "lights"
TYPE RASTER
STATUS ON
DATA
"E:/Dev/Tools/mapserver/workshop/reuven/data/nitelti020l.tif"
END
LAYER
NAME "boundaries"
TYPE POLYGON
STATUS ON
DATA "statesp020"
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=NAD83"
END
CLASS
NAME "US states"
OUTLINECOLOR 50 50 50
SYMBOL 0
END
END
END
All of the files are under the following directory:
(including: nitelti020l.tif and
statesp020.shp/shx/dbf)
This is the template contents (reuven.html in same
directory as map file):
<input type="image" name="img" src="[img]"
width="[mapwidth]" height="[mapheight]" border="0"
alt="this is the map">
I am calling the server with the following URL:
http://localhost/cgi-bin/mapserv.exe?&map=E:/Dev/Source/web/workshop/reuven.map
Version information:
MapServer version 4.2.0 OUTPUT=GIF OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLI
ENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
I am sure the problem is something simple, but I am
just not seeing it.
Thanks in advance for any help,
Sincerely,
Reuven
