[SPAM] - Re: [UMN_MAPSERVER-USERS] WGS84 gps point in postgis
- Sending mail server found on relays.ordb.org
Stéphane RIFF
stephane.riff at CERENE.FR
Fri Aug 20 11:00:41 EDT 2004
Big Thanks to answerers, i'm now capable to view GPS point on my map.
The problem is that reprojection doesn't seem to apply on FEATURE layer
BYE
Stéphane RIFF wrote:
>>> Hello,
>>> I want to store WGS84 gps points in a postgis table:
>>> What is the format of WGS84 point in postgis ???
>>> For now i have something like this:
>>> SRID=4326;POINT(DDMM.SSSS DDMM.SSSS) ----> is that
>>> ok ???
>>> Next i want to show those gps points on raster map in other projection:
>>> epsg:27582 (lambert II etendu)
>>> Does somebody already do something like that...
>>> All advices are wellcome
>>> Thanks
>> Hi,
>> just as Vladimir pointed out the format should be something like:
>> SRID=4326;POINT(7.0725 50.73882)
>> You need a geometry field in the table, so after creating the TABLE
>> (named umn_user in this example) itself:
>> CREATE TABLE umn_user (
>> gid integer,
>> firstname character varying,
>> lastname character varying,
>> you have to add the field that contains the geometry (DATBASE germany,
>> TABLE umn_user, FIELD the_geom, SRID, Type, dimension):
>> SELECT AddGeometryColumn('germany', 'umn_user', 'the_geom', 4326,
>> 'POINT', 2);
>> then you can add values:
>> INSERT INTO umn_user VALUES (42, Stephane, Riff, ... ,
>> 'SRID=4326;POINT(7.07250238209242 50.7387903487365)';
>> Now you can add WMS capabilities to the MAP file and query MapServer
>> with WMS syntax. Then you can switch projections on the fly by just
>> adding another EPSG code to the getMap string. The WMS client
>> Mapbender includes that functionality, check it out here:
>> http://www.mapbender.org/testbed.html
>> The testbed currently contains 3 WMS and as you can see not all of
>> them answer to all EPSGs.
>> Cheers, Arnulf.
> Thanks for answer,
> Now i tried this but it doesn't work:
> the mapfile :
> MAP
> NAME HELLO
> STATUS ON
> EXTENT 47673.624 1616618.5 1197873.624 2677218.5 #extent of France
> SIZE 400 300
> IMAGECOLOR 200 255 255
> WEB
> IMAGEPATH "/var/apache/web/tmp/"
> IMAGEURL "/tmp/"
> END
> PROJECTION
> "init=epsg:27582" # lambert II
> END
> LAYER
> NAME "credits"
> STATUS DEFAULT
> TRANSFORM FALSE
> TYPE ANNOTATION
> PROJECTION
> "init=epsg:4326" #WGS84
> END
> FEATURE
> POINTS
> END
> TEXT 'Hello world. Mapserver rocks.'
> END
> CLASS
> LABEL
> TYPE BITMAP
> COLOR 255 0 0
> END
> SIZE 16
> END
> END
> END
> I can't see anything, do i miss something
> Hope someone could help
> THX
