Mapserver Displays Incorrect Image, Help!
David Horowitz
mapuser at VERYSPEEDY.NET
Fri Aug 20 14:21:04 EDT 2004
I am experiencing a strange bug with mapserver, hoping someone can
help. The application uses the rosa applet. Occasionally after zooming
or paning, mapserver displays an image already generated from a previous
session instead of generating the appropriate new image. The
application expriencing the problem is running on a Redhat 9 system.
Oddly, a mapserver installation running an identical application seems
to work perfectly fine on a Windows machine. Any ideas?
The only thing I can think of is that mapserver either isn't generating
a unique identifier for each image or generates a unique identifier but
selects the incorrect identifier to display. Are these possiblilites?
If it helps, the link to the application is:
http://www.cattlab.umd.edu/region. Thank you.
