Mapserver Displays Incorrect Image, Help!
Jacob Delfos
jacob.delfos at MAUNSELL.COM
Sun Aug 22 20:38:39 EDT 2004
David,
I didn't notice any problems from the link you gave. But typically if you get 'old information', it means somewhere something is caching something. Maybe your browser is caching images, or something else is. Try accessing it from a different browser.
Jacob
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of David Horowitz
Sent: 21 August 2004 02:21
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Mapserver Displays Incorrect Image, Help!
I am experiencing a strange bug with mapserver, hoping someone can
help. The application uses the rosa applet. Occasionally after zooming
or paning, mapserver displays an image already generated from a previous
session instead of generating the appropriate new image. The
application expriencing the problem is running on a Redhat 9 system.
Oddly, a mapserver installation running an identical application seems
to work perfectly fine on a Windows machine. Any ideas?
The only thing I can think of is that mapserver either isn't generating
a unique identifier for each image or generates a unique identifier but
selects the incorrect identifier to display. Are these possiblilites?
If it helps, the link to the application is:
http://www.cattlab.umd.edu/region. Thank you.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040823/a7024d55/attachment.html
