Python Mapscript :: NameError: global name 'rectObj' is not
defined
Bill Hudspeth
bhudspeth at EDAC.UNM.EDU
Mon Aug 23 14:52:28 EDT 2004
Sean Gillies wrote:
> Bill, I'm cc'ing to the list. More at the bottom ...
> On Aug 23, 2004, at 12:03 PM, Bill Hudspeth wrote:
>> Sean Gillies wrote:
>>> On Aug 23, 2004, at 10:42 AM, Bill Hudspeth wrote:
>>>> I am trying to create a rectangle object using Python Mapscript as
>>>> such:
>>>> prevExtent = rectObj(self.prev_minx, self.prev_miny, self.prev_maxx,
>>>> self.prev_maxy)
>>>> and get the following error message:
>>>> NameError: global name 'rectObj' is not defined
>>>> I have imported the mapscript module - other mapscript objects are
>>>> recognized in different calls throughout my code, so that is not the
>>>> problem.
>>>> Any other ideas would be greatly appreciated.
>>>> Thanks, Bill
>>> Bill,
>>> There's two different styles of using mapscript classes
>>> 1. keep mapscript class names inside the 'mapscript' namespace:
>>> import mapscript
>>> r = mapscript.rectObj()
>>> 2. import names into the global namespace:
>>> from mapscript import rectObj
>>> r = rectObj()
>>> I don't recommend 'from mapscript import *'.
>>> cheers,
>>> Sean
>>> Sean Gillies
>>> sgillies at frii dot com
>>> http://users.frii.com/sgillies
>> Hi Sean,
>> Your suggestion above worked, but I am getting a new error message
>> from the following line of code:
>> prevExtent = mapscript.rectObj(self.prev_minx, self.prev_miny,
>> self.prev_maxx, self.prev_maxy)
>> The error message is:
>> General error message: invalid bounds
>> The variables I pass in for minx, miny, maxx, and maxy do evaluate to
>> floating point utm boundaries (e.g. 580000.0 3400000.0 250799.0
>> 4153198.0) - I can print them out to screen.
>> Thanks again, Bill
> I see in your example values that minx (580000.0) > maxx (250799.0).
> This is invalid.
> Did you get them switched up?
> If you think the error message is unclear, lemme know. I'm always open
> to suggestions.
> What version of MapServer are you using?
> cheers,
> Sean
> Sean Gillies
Hi Sean,
I believe that I am deriving the extents attributes from the map file,
like this:
self.nmMap = mapscript.mapObj(self.data)
self.default_extent = self.nmMap.extent
self.prev_minx=self.default_extent.minx
self.prev_maxx=self.default_extent.maxx
self.prev_miny=self.default_extent.miny
self.prev_maxy=self.default_extent.maxy
Shouldn't the "self.default_extent.minx" entries pull out the correct
values from the map file?
my map file listing ---> EXTENT 580000 3400000 250799 4153198
Are my attributes in the call to rectObj in the correct order? Am I
missing something else?
Again, thanks. Bill
