Solved !! Mapserver crash on text Flash (SWF) output...
known problem?
Reuven Levitt
reuven at LEVITT.NET
Mon Aug 23 20:20:31 EDT 2004
Ok it looks like I am having a conversation with
myself, but at least this is all saved so people with
the same problems my find my solutions.
Anyways I found that the FDB fonts on the ming site do
not work for me (I just get a mess).
I found these FDB fonts that do work:
http://ploticus.sourceforge.net/download/fdbfonts.tar.gz
Either way, I now have my test case working, and I can
start working on solving some real world problems.
I am sure I will be asking more questions soon :)
Thanks to everyone for the feedback and help,
Reuven.
--- Reuven Levitt <reuven at LEVITT.NET> wrote:
> Part of the problem was solved by using FDB fonts
> (Thanks for the tip Yewondwossen). Ming seg-faults
> if
> TTF are used.
> However, I found that I must also not use the
> FULL_RESOLUTION=FALSE or TRUE
> If this parameter is set no text shows up.
> However now that text is showing up it is coming up
> as
> Giberish (nonsence character strings).
> Any tips? Anyone? Please???
> Reuven.
> > Hi Everyone,
> > I am relatively new to Mapserver, but have spent
> the
> > last 6 days working around 12 hours a day. So I
> am
> > definitly getting some experience. It is an
> amazing
> > piece of software !
> > The Flash output stuff I wrote works well
> (including
> > the demo on the Mapserver site). However when I
> try
> > and get Mapserver to output any type of text to
> > flash
> > output Mapserver simply crashes (On windows XP).
> > This only happens when
> > FORMATOPTION
> "OUTPUT_MOVIE=MULTIPLE"
> > however it does not crash with:
> > FORMATOPTION "OUTPUT_MOVIE=SINGLE"
> > Crash means windows: "mapserv.exe has encountered
> a
> > problem and needs to close. We are sorry for the
> > inconvenience."
> > I created a very simple test case to see if it
> still
> > crashes, and it does. Here is the map file:
> > MAP
> > NAME FMV
> > STATUS ON
> > IMAGETYPE swf
> > SIZE 800 600
> > SHAPEPATH "data"
> > IMAGECOLOR 255 255 255
> > EXTENT -180 -80 180 80
> > FONTSET
> > "E:\Dev\Source\web\workshop\fonts\font.list"
> > # EXTENT 0 0 20 20
> > PROJECTION "proj=latlong" END
> > WEB
> > log "./tmp/fmv.log"
> > TEMPLATE 'fmv_template.html'
> > IMAGEPATH './tmp/'
> > IMAGEURL
> > 'http://localhost/workshop/fmv/tmp/'
> > END
> > OUTPUTFORMAT
> > NAME swf
> > DRIVER "SWF"
> > MIMETYPE
> > "application/x-shockwave-flash"
> > EXTENSION "swf"
> > IMAGEMODE PC256
> > FORMATOPTION
> > END
> > LAYER
> > NAME "credits"
> > STATUS DEFAULT
> > TRANSFORM FALSE
> > TYPE ANNOTATION
> > FEATURE
> > POINTS
> > 10 480
> > END
> > TEXT 'Made by Mapserver.'
> > END
> > CLASS
> > LABEL
> > TYPE TRUETYPE
> > FONT "arial"
> > POSITION CR
> > COLOR 0 0 0
> > SIZE 8
> > END
> > END
> > END
> > END
> > All the other files are the ones that come with
> the
> > mapserver flash demo (FMV).
> > MapServer version 4.2.0 OUTPUT=GIF OUTPUT=PNG
> > OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> > OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
> > SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLI
> > ENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> > INPUT=SHAPEFILE
> > Any help would be greatly appreciated !
> > Also if someone could test this on their setup to
> > see
> > if it works that would be great.
> > Thanks
> > Reuven.
