shp2mysql.pl problems
dylan
dylan at IICI.NO-IP.ORG
Tue Aug 24 04:19:17 EDT 2004
greetings!
i am new to mapserver, and am excited about its integration with mysql...
i just spent the evening trying to figure out how to make shp2mysql.pl work.
perhaps i am not understanding perl modules, but try as i might i am not
able to make this script function correctly!
after installing the ShapeFile.pm (and ShapeFile/Shape.pm ) in the
appropriate directories i get this when running shp2mysql.pl:
/src/mapserver-4.2.2$ ./shp2mysql.pl
Can't locate Shape.pm in @INC (@INC contains: /usr/local/lib/perl/5.6.1
/usr/local/share/perl/5.6.1 /usr/lib/perl5 /usr/share/perl5
/usr/lib/perl/5.6.1 /usr/share/perl/5.6.1 /usr/local/lib/site_perl .) at
./shp2mysql.pl line 9.
BEGIN failed--compilation aborted at ./shp2mysql.pl line 9.
Shape.pm lives in : /usr/local/share/perl/5.6.1/Geo/ShapeFile/Shape.pm
i have tried manually moving Shape.pm to the /usr/local/share/perl/5.6.1
dir, but that doesn't work either...
i have tried modifying the shp2mysql.pm file:
#use Shape qw/:all/;
use Geo::ShapeFile::Shape qw/:all/;
...and...
#$shape = new Shape $ARGV[0];
$shape = new Geo::ShapeFile::Shape $ARGV[0];
...after doing so results in sph2mysql.pl to run with no arguments... but
when i specify a shapefile:
./shp2mysql.pl ../../public_html/mapserver/ca_county/ca_cnty
Odd number of elements in hash assignment at
/usr/local/share/perl/5.6.1/Geo/ShapeFile/Shape.pm line 30.
this corresponds to the line marked with a *:
sub new {
my $proto = shift;
my $class = ref($proto) || $proto;
* my %args = @_;
my $self = {
... any ideas on this mess?
thanks in advance!
Dylan
