shp2mysql.pl problems
Lowell Filak
lfilak at MEDINACO.ORG
Mon Aug 23 10:21:14 EDT 2004
I think the documentation points to installing Geo-Shapelib vs.
Geo-ShapeFile .
HTH
Lowell
The following message was sent by dylan <dylan at IICI.NO-IP.ORG> on Tue,
24 Aug 2004 01:19:17 -0700.
> greetings!
> i am new to mapserver, and am excited about its integration with mysql...
> i just spent the evening trying to figure out how to make shp2mysql.pl
work.
> perhaps i am not understanding perl modules, but try as i might i am not
> able to make this script function correctly!
> after installing the ShapeFile.pm (and ShapeFile/Shape.pm ) in the
> appropriate directories i get this when running shp2mysql.pl:
> /src/mapserver-4.2.2$ ./shp2mysql.pl
> Can't locate Shape.pm in @INC (@INC contains: /usr/local/lib/perl/5.6.1
> /usr/local/share/perl/5.6.1 /usr/lib/perl5 /usr/share/perl5
> /usr/lib/perl/5.6.1 /usr/share/perl/5.6.1 /usr/local/lib/site_perl .) at
> ./shp2mysql.pl line 9.
> BEGIN failed--compilation aborted at ./shp2mysql.pl line 9.
> Shape.pm lives in : /usr/local/share/perl/5.6.1/Geo/ShapeFile/Shape.pm
> i have tried manually moving Shape.pm to the /usr/local/share/perl/5.6.1
> dir, but that doesn't work either...
> i have tried modifying the shp2mysql.pm file:
> #use Shape qw/:all/;
> use Geo::ShapeFile::Shape qw/:all/;
> ...and...
> #$shape = new Shape $ARGV[0];
> $shape = new Geo::ShapeFile::Shape $ARGV[0];
> ...after doing so results in sph2mysql.pl to run with no arguments... but
> when i specify a shapefile:
> ./shp2mysql.pl ../../public_html/mapserver/ca_county/ca_cnty
> Odd number of elements in hash assignment at
> /usr/local/share/perl/5.6.1/Geo/ShapeFile/Shape.pm line 30.
> this corresponds to the line marked with a *:
> sub new {
> my $proto = shift;
> my $class = ref($proto) || $proto;
> * my %args = @_;
> my $self = {
> ... any ideas on this mess?
> thanks in advance!
> Dylan
