Win Mapserver Postgis layer error again
Mladen Kotarac
mladen.kotarac at CKFF.SI
Tue Aug 24 09:07:36 EDT 2004
It looks to me that the problem lies on the Mapserver side,
since all this queries execute perfectly when accessing
my Win PostgreSQL/Postgis installation with other API's.
Mladen
Paul Spencer wrote:
> I can definitely tell you from bitter ;) experience recently that you
> MUST use lower case "from" in the sql, i.e.
> the_geom from not1
> is the correct version to use. I can't help you with why it crashes
> postgresql, but I can say that I have got it working successfully on
> winxp using the ms4w packages from http://www.maptools.org/ms4w so it is
> possible.
> Cheers,
> Paul
> Mladen Kotarac wrote:
>> I am getting closer :-(
>> Data string: "the_geom FROM not1" produces this error:
>> *Warning*: [MapServer Error]: prep_DB(): Error executing POSTGIS DECLARE
>> (the actual query) statement: 'DECLARE mycursor BINARY CURSOR
>> FOR SELECT
>> asbinary(force_collection(force_2d(� ’ p— )),'NDR'),OID::text
>> from ŕĎQ p— WHERE � ’ p— && setSRID('BOX3D(365000 8906.25,635000
>> 211093.75)'::BOX3D, find_srid('','ŕĎQ p— ','� ’ p— ') )'
>> Postgresql reports the error as 'ERROR: syntax error at or near " " at
>> character 79 '
>> while data string "the_geom from not1" simply crashes the PostgreSQL.
>> Any help would be appreciated.
>> BR
>> Mladen
>> Mladen Kotarac, univ.dipl.biol.
>> Center za kartografijo favne in flore
>> Centre for Cartography of Fauna and Flora
>> http://www.ckff.si
>> Antoliciceva 1, SI-2204 Miklavž na Dravskem polju, Slovenija
>> tel: 00386-(0)2-6295150
>> fax: 00386-(0)2-6295151
>> podružnica Ljubljana, Zemljemerska 10, SI-1000 Ljubljana, Slovenija
>> tel: 00386-(0)1-4382440
>> fax: 00386-(0)1-4382445
>> GSM: 00386-(0)41-735429
>> e-mail: mladen.kotarac at ckff.si
> |Paul Spencer pspencer at dmsolutions.ca |
> |Applications & Software Development |
> |DM Solutions Group Inc http://www.dmsolutions.ca/|
http://www.ckff.si
