Cascading from the same server
Howard Mark
MHoward at SPACEIMAGING.COM
Tue Aug 24 16:21:51 EDT 2004
I'm attempting to create a single layer from a group of layers by cascading a WMS call from a server to itself.
The WMS layer is defined in one map file and the layers it references are in another.
An HTTP call to draw the second map (group of layers) works fine, but a call to the first map - using the WMS layer results in a "cannot draw layer" error.
Is this cascading not possible? Or should I look for typos...?
TIA for any info
Mark
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
