Cascading from the same server
Gregor Mosheh
stigmata at BLACKANGEL.NET
Tue Aug 24 17:20:09 EDT 2004
I came across this a few months ago, too:
No, MapServer can't do cascading WMS.
On Tue, 24 Aug 2004, Howard Mark wrote:
> I'm attempting to create a single layer from a group of layers by cascading a WMS call from a server to itself.
> The WMS layer is defined in one map file and the layers it references are in another.
> An HTTP call to draw the second map (group of layers) works fine, but a call to the first map - using the WMS layer results in a "cannot draw layer" error.
> Is this cascading not possible? Or should I look for typos...?
> TIA for any info
> Mark
> This message is intended only for the use of the Addressee and may
> contain information that is PRIVILEGED and CONFIDENTIAL.
> If you are not the intended recipient, you are hereby notified that any
> dissemination of this communication is strictly prohibited. If you have
> received this communication in error, please erase all copies of the
> message and its attachments and notify Space Imaging immediately.
Gregor Mosheh, B.S. http://www.blackangel.net/
43rd Law of Computing:
Anything that can go wr
fortune: Segmentation violation -- Core dumped
