simple query on shapefile [solved!]
dylan
dylan at IICI.NO-IP.ORG
Wed Aug 25 15:03:49 EDT 2004
Brant,
thank you very much for the pointers!! after adding the query template all
was well... furthermore, after reviewing the docs that you sent my way i am
starting to get a better idea of how mapserver works!!
thanks again! mapserver is great!!
Dylan E. Beaudette
Soil Science Graduate Group
Dept. of Land, Air, and Water Resources
University of California at Davis
on 04.8.24 5:20 PM, Brant Anderson at brant at MUDLABS.COM was reported to have
writen:
> Greetings Dylan,
> WEB
> TEMPLATE 'map.html' # This is what I consider the "GLOBAL" browse mode
> template... to do a query, you need a template assigned to that layer.
> IMAGEPATH '/home/dylan/public_html/mapserver/ca_county/temp/'
> IMAGEURL '/~dylan/mapserver/ca_county/temp/'
> END
> Here is your current layer definition:
> # Start of LAYER DEFINITIONS ---------------------------------------------
> LAYER # ca county polygon layer begins here
> NAME ca_cnty
> TYPE POLYGON
> CONNECTIONTYPE OGR
> CONNECTION "ca_cnty.shp"
> #DATA "SELECT * from poly"
> STATUS DEFAULT
> CLASS
> COLOR 50 100 220
> OUTLINECOLOR 32 32 32
> END
> END # ca county polygon layer ends here
> # End of LAYER DEFINITIONS -------------------------------
> Here is a modified version of your layer:
> NAME ca_cnty
> TYPE POLYGON
> CONNECTIONTYPE OGR
> STATUS DEFAULT
> HEADER 'templates/ca_cnty_header.html' # Appears once as the header
> FOOTER 'templates/ca_cnty_footer.html' # Appears once as the footer
> CLASS
> COLOR 50 100 220
> TEMPLATE 'templates/ca_cnty.html # Loops one instance for each record. This is
> the template file that will be read for querying on this layer... If you query
> on multiple layers, you may want to add a HEADER and FOOTER tag to the WEB
> section.
> END
> Here are a couple of links that might be helpful:
> Mapfile Reference: http://mapserver.gis.umn.edu/doc42/mapfile-reference.html
> Template Reference:
> http://mapserver.gis.umn.edu/doc42/template-reference.html
> A good way to get a grasp on this is through experimentation. Look at
> the generated HTML code for patterns as a guide to help troubleshoot any
> problems.
> Hope this helps!
> Good Luck!
> Brant Anderson
> Dylan Beaudette wrote:
>> greetings,
>> i am trying to query a simple map of california counties here:
>> http://169.237.34.168/~dylan/mapserver/ca_county/map.html
>> however, when the mode is set to nquery, a click on the map results in
>> the following error:
>> msQueryByPoint(): Search returned no results. No matching record(s)
>> found.
>> i have tried looking over some of the example mapserver pages, but
>> cannot figure out how the query mechanism really works...
>> any points on how to get a working query system setup?
>> here is the source for my .map file:
>> http://169.237.34.168/~dylan/mapserver/ca_county/ca_county.map
>> any ideas?
>> thanks in advance!
>> Dylan Beaudette
