PostGIS Classification works in 4.0.2 not in >= 4.2
Daryl Herzmann
akrherz at IASTATE.EDU
Wed Aug 25 20:29:06 EDT 2004
Howdy,
I have a PostGIS layer (see below). With mapserver 4.0.2, the classication
works, Flash Flood Warnings (FFW) are colored green and so on. With
4.2.2, the FFWs are coloured yellow (SVR) like Severe warnings. Here is
an example plot with 4.2.2
http://mesonet.agron.iastate.edu/pickup/n0r_20040825_2225.png
and then the correct image five minutes later with 4.0.2
http://mesonet.agron.iastate.edu/pickup/n0r_20040825_2230.png
Notice the counties that turned green, like they should be! :)
What am I doing wrong?
daryl
LAYER
CONNECTIONTYPE postgis
NAME warnings0_c
CONNECTION "user=akrherz dbname=postgis host=10.10.10.10"
DATA "geom from (select type as wtype, geom, oid from warnings WHERE
gtype = 'C' and expire > CURRENT_TIMESTAMP ORDER by expire, type ASC)
as foo"
STATUS ON
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CLASSITEM wtype
CLASS
EXPRESSION 'TOR'
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
SIZE 2
SYMBOL 1
END
CLASS
EXPRESSION 'SVR'
COLOR -1 -1 -1
OUTLINECOLOR 255 255 0
SIZE 2
SYMBOL 1
END
CLASS
EXPRESSION 'FFW'
COLOR -1 -1 -1
OUTLINECOLOR 0 255 0
SIZE 2
SYMBOL 1
END
END
* Daryl Herzmann (akrherz at iastate.edu)
* Program Assistant -- Iowa Environmental Mesonet
* http://mesonet.agron.iastate.edu
