PostGIS Classification works in 4.0.2 not in >= 4.2
Sean Gillies
sgillies at FRII.COM
Thu Aug 26 09:44:07 EDT 2004
On Aug 25, 2004, at 6:29 PM, Daryl Herzmann wrote:
> Howdy,
> I have a PostGIS layer (see below). With mapserver 4.0.2, the
> classication
> works, Flash Flood Warnings (FFW) are colored green and so on. With
> 4.2.2, the FFWs are coloured yellow (SVR) like Severe warnings. Here
> is
> an example plot with 4.2.2
> http://mesonet.agron.iastate.edu/pickup/n0r_20040825_2225.png
> and then the correct image five minutes later with 4.0.2
> http://mesonet.agron.iastate.edu/pickup/n0r_20040825_2230.png
> Notice the counties that turned green, like they should be! :)
> What am I doing wrong?
> daryl
> LAYER
> CONNECTIONTYPE postgis
> NAME warnings0_c
> CONNECTION "user=akrherz dbname=postgis host=10.10.10.10"
> DATA "geom from (select type as wtype, geom, oid from warnings WHERE
> gtype = 'C' and expire > CURRENT_TIMESTAMP ORDER by expire, type
> ASC)
> as foo"
> STATUS ON
> TYPE POLYGON
> PROJECTION
> "init=epsg:4326"
> END
> CLASSITEM wtype
> CLASS
> EXPRESSION 'TOR'
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> SIZE 2
> SYMBOL 1
> END
> CLASS
> EXPRESSION 'SVR'
> COLOR -1 -1 -1
> OUTLINECOLOR 255 255 0
> SIZE 2
> SYMBOL 1
> END
> CLASS
> EXPRESSION 'FFW'
> COLOR -1 -1 -1
> OUTLINECOLOR 0 255 0
> SIZE 2
> SYMBOL 1
> END
> END
> * Daryl Herzmann (akrherz at iastate.edu)
> * Program Assistant -- Iowa Environmental Mesonet
> * http://mesonet.agron.iastate.edu
Hi Daryl,
That's odd. Could you try labelling the polygons to see what
is their wtype? LABELITEM "wtype".
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
