PostGIS Classification works in 4.0.2 not in >= 4.2
Sean Gillies
sgillies at FRII.COM
Thu Aug 26 10:55:06 EDT 2004
On Aug 26, 2004, at 8:30 AM, Daryl Herzmann wrote:
> Hi Sean!
> On Thu, 26 Aug 2004, Sean Gillies wrote:
>> On Aug 25, 2004, at 6:29 PM, Daryl Herzmann wrote:
>>> Howdy,
>>> I have a PostGIS layer (see below). With mapserver 4.0.2, the
>>> classication
>>> works, Flash Flood Warnings (FFW) are colored green and so on. With
>>> 4.2.2, the FFWs are coloured yellow (SVR) like Severe warnings.
>>> Here is
>>> an example plot with 4.2.2
>>> http://mesonet.agron.iastate.edu/pickup/n0r_20040825_2225.png
>>> and then the correct image five minutes later with 4.0.2
>>> http://mesonet.agron.iastate.edu/pickup/n0r_20040825_2230.png
>>> Notice the counties that turned green, like they should be! :)
>>> What am I doing wrong?
>>> daryl
>>> LAYER
>>> CONNECTIONTYPE postgis
>>> NAME warnings0_c
>>> CONNECTION "user=akrherz dbname=postgis host=10.10.10.10"
>>> DATA "geom from (select type as wtype, geom, oid from warnings
>>> WHERE
>>> gtype = 'C' and expire > CURRENT_TIMESTAMP ORDER by expire, type
>>> ASC)
>>> as foo"
>>> STATUS ON
>>> TYPE POLYGON
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> CLASSITEM wtype
>>> CLASS
>>> EXPRESSION 'TOR'
>>> COLOR -1 -1 -1
>>> OUTLINECOLOR 255 0 0
>>> SIZE 2
>>> SYMBOL 1
>>> END
>>> CLASS
>>> EXPRESSION 'SVR'
>>> COLOR -1 -1 -1
>>> OUTLINECOLOR 255 255 0
>>> SIZE 2
>>> SYMBOL 1
>>> END
>>> CLASS
>>> EXPRESSION 'FFW'
>>> COLOR -1 -1 -1
>>> OUTLINECOLOR 0 255 0
>>> SIZE 2
>>> SYMBOL 1
>>> END
>>> END
>>> * Daryl Herzmann (akrherz at iastate.edu)
>>> * Program Assistant -- Iowa Environmental Mesonet
>>> * http://mesonet.agron.iastate.edu
>> Hi Daryl,
>> That's odd. Could you try labelling the polygons to see what
>> is their wtype? LABELITEM "wtype".
> Thanks for the idea. See the results :(
> MS 4.0.2
> http://mesonet.agron.iastate.edu/pickup/ms402.png
> MS 4.2.2
> http://mesonet.agron.iastate.edu/pickup/ms422.png
> I changed the data line from above to
> DATA "geom from (select type as wtype, geom, oid from warnings WHERE
> gtype = 'C' and expire > '2004-08-25 17:25' and
> issue < '2004-08-25 17:25' ORDER by expire, type ASC) as foo"
> for testing purposes...
> thanks,
> daryl
Daryl, will you create a new bug in bugzilla? There's talk of a
4.2.3 release, so it's important that you get the new bug in ASAP.
CC me and mapserver-bugs at dmsolutions.ca and i'll raise the priority
to a blocker while we look at it.
Attach your mapfile fragment and the images.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
