OGR - Access to Mapinfo
Pierre RELLA
Pierre.RELLA at AGRICULTURE.GOUV.FR
Fri Aug 27 04:13:03 EDT 2004
When i want to view a vector layer in format Mapinfo (.tab") i have the
message
"msOGRLayerOpen(): General error message. OGR support is not available" and
In format ESRI(.shp) it works
In the mapefile i write:
LAYER
NAME "lakes"
TYPE POLYGON
CONNECTIONTYPE OGR
DATA "couche_shp/lakes.tab"
STATUS OFF
CLASS
OUTLINECOLOR 0 0 0
COLOR 255 255 255
END
END
If i change the "lakes.tab" by "lakes.shp" i have the same problem.
thank for your help,
Bests regards
