OGR - Access to Mapinfo
Bart van den Eijnden
bartvde at XS4ALL.NL
Fri Aug 27 04:40:42 EDT 2004
is your Mapserver compiled with OGR support (INPUT=OGR)?
Check with mapserv -v
c:\ms4w\cgi-bin>mapserv -v
MapServer version 4.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7
INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Mapserver can natively (without OGR) display shapefiles, but for Mapinfo
files the OGR support needs to be compiled in.
Best regards,
Bart
> Hi,
> When i want to view a vector layer in format Mapinfo (.tab") i have the
> message
> "msOGRLayerOpen(): General error message. OGR support is not available"
> and
> In format ESRI(.shp) it works
> In the mapefile i write:
> LAYER
> NAME "lakes"
> TYPE POLYGON
> CONNECTIONTYPE OGR
> DATA "couche_shp/lakes.tab"
> STATUS OFF
> CLASS
> OUTLINECOLOR 0
> COLOR 255 255 255
> END
> END
> If i change the "lakes.tab" by "lakes.shp" i have the same problem.
> thank for your help,
> Bests regards
