OGR - Access to Mapinfo
fx gamoy
fx.gamoy at MAPXPLORE.COM
Fri Aug 27 05:04:46 EDT 2004
Hello,
you can try :
LAYER
NAME "lakes"
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "couche_shp/lakes.tab" // (or absolute path) - linux plateform
sould be case sensitive -> .TAB
STATUS ON
CLASS
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 255 255 255
SIZE 1
END
END
Bon courage
fx gamoy
http://www.geomatika.fr/
----- Original Message -----
From: "Pierre RELLA" <Pierre.RELLA at AGRICULTURE.GOUV.FR>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, August 27, 2004 10:13 AM
Subject: [UMN_MAPSERVER-USERS] OGR - Access to Mapinfo
When i want to view a vector layer in format Mapinfo (.tab") i have the
message
"msOGRLayerOpen(): General error message. OGR support is not available" and
In format ESRI(.shp) it works
In the mapefile i write:
LAYER
NAME "lakes"
TYPE POLYGON
CONNECTIONTYPE OGR
DATA "couche_shp/lakes.tab"
STATUS OFF
CLASS
OUTLINECOLOR 0 0 0
COLOR 255 255 255
END
END
If i change the "lakes.tab" by "lakes.shp" i have the same problem.
thank for your help,
Bests regards
