POSTLABELCACHE
Astrid Emde
astrid.emde at CCGIS.DE
Fri Aug 27 06:04:22 EDT 2004
Hello list,
I have a problem with POSTLABELCACHE.
In my mapfile I have an Annotaion-Layer. For the labeling I defined a
backgroundcolor. By default for Annotaion-Layers the LABELCACHE is true.
That means all Layers are drawn and at the end the ANNOTAION-Layers are
drawn on top.
But I want the map tp be drawn in the order I defined in the mapfile. I
set POSTLABELCACHE FALSE but still the ANNOTAION-Layer is drawn on top.
Does anyone has an idea?
LAYER
NAME "text"
TYPE Annotation
STATUS ON
CONNECTIONTYPE postgis
CONNECTION "user=admin dbname=cities host=localhost"
DATA "the_geom from (select * from text) as foo using unique oid using
SRID=31466"
METADATA
WMS_SRS 'epsg:31466'
WMS_TITLE 'Text'
WMS_FEATURE_INFO_MIME_TYPE 'text/html'
END
PROJECTION
"init=epsg:31466"
END
CLASSITEM 'objart'
LABELITEM 'label'
LABELANGLEITEM 'winkel'
CLASS
NAME '0233'
EXPRESSION /^233/
LABEL
TYPE TRUETYPE
FONT 'arialnarrowkursiv'
SIZE 7.08661417322835
POSITION cc
WRAP "/"
COLOR 255 0 0
PARTIALS FALSE
FORCE True
BUFFER 1
BACKGROUNDCOLOR 254 254 254
END
END
END # END of Layer....
Thanx for your help
Astrid Emde
