class expression problem
Tomasz Wlaz?owski
wlazlowski at IGPIK.WAW.PL
Fri Aug 27 08:20:14 EDT 2004
Thank you for your prompt answer.
On this link that you gave me I can’t find any thing that could help me
with my problem...
I expect that I will have to use some syntax with [imgx] and [imgy] or
with [shpmid] but I don’t know how?
The point is that I want to zoom to selected object (from my select
menu) in main map window. I know that if I want to receive map with
zoomed object I can use a query/nquery mode.
I’m looking the way how to get attribute (from attribute table/ from
*shape column) that refers to shape of every object.
Tomasz Wlazlowski
Insitute of Spatial Management and Housing
wlazlowski at igpik.waw.pl
