JPEG 2000 format instead of TIFF for a RASTER layer
Brant Anderson
brant at MUDLABS.COM
Fri Aug 27 18:45:11 EDT 2004
Correct me if I am wrong, but I am using a TILEINDEX layer as a
reference for each tile. Therefore, a georeferenced image nor a world
file is required (the layer provides this information).
Brant
Frank Warmerdam wrote:
> Brant Anderson wrote:
>> Okay.
>> This time I compiled 'jasper' without the geo referencing 'geojasper' so
>> now I am using plain Jasper.
>> I then compiled GDAL with the new ungeofied (GeoJP2=no) Jasper library.
>> Then I tried to view my map. The server didn't give an Internal Server
>> Error this time! But a new problem is here. The images just don't show
>> up. I viewed the JPEG2000 images with "Image Viewer 2" in Windows, and
>> they appear just fine, so I know they are supposed to be there. The
>> layer used for tiling uses the same shapes as the TIFF version did, so
>> the Extent values should be proper.
> Brant,
> If you don't compile with the georeferencing enabled version of JasPer
> then your map won't work because GDAL won't know where your .jp2 images
> are. The message that was causing the problem must be coming from
> somewhere
> in the GDAL JasPer driver or in the JasPer library itself. Just grep
> for it
> and strip it out and rebuild.
> > Maybe someone could test it out on their system. That way I can find
> out
> > if it is a server configuration problem, or a syntax problem.
> I downloaded the .map file and the jpeg2000 data and tested it on my
> system. It worked fine with "shp2img -m test.map -o out.png" once I
> had adjusted the SHAPEPATH, and set STATUS to DEFAULT in the layer
> in question.
> I also checked the .jp2 files and they look find with reasonable
> georeferencing.
> Note all my testing was with a Kakadu based version of GDAL, not using
> JasPer.
> Can you run gdalinfo on one of the .jp2 files yourself now that you have
> switched to the non-geo JasPer version? I think you will find the bounds
> and coordinate system are no longer known. Assuming that is true, you
> will
> really need to use the geo enabled version of JasPer and ensure that the
> debug message is removed.
> If you are using the most recent "geo-JasPer" version and you can't
> figure out
> how to get the problematic message out you should contact Andrey Kiselev
> (dron at remotesensing.org should get to him) about it. He maintains the
> JasPer driver in GDAL.
> Finally I would like to stress that the JasPer driver in GDAL has
> performance
> issues. It is very memory hungry for large images and is somewhat slower
> than Kakadu. Given the smallish size of your tiles you shouldn't have
> much
> problem with the memory use. In addition to the JasPer and Kakadu based
> GDAL JPEG2000 drivers, the new ECW SDK 3.0 also supports JPEG2000
> support and
> is free.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
