JPEG 2000 format instead of TIFF for a RASTER layer
Ed McNierney
ed at TOPOZONE.COM
Fri Aug 27 19:24:15 EDT 2004
Brant -
No, that is not correct. The TILEINDEX indentifies which tiles might
possibly intersect the current output map area, but georeferencing for
each individual image is still required.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 978 251-4242 Fax: +1 978 251-1396
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Brant Anderson
Sent: Friday, August 27, 2004 6:45 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] JPEG 2000 format instead of TIFF for
a RASTER layer
Correct me if I am wrong, but I am using a TILEINDEX layer as a
reference for each tile. Therefore, a georeferenced image nor a world
file is required (the layer provides this information).
Brant
Frank Warmerdam wrote:
> Brant Anderson wrote:
>> Okay.
>> This time I compiled 'jasper' without the geo referencing 'geojasper'
>> so now I am using plain Jasper.
>> I then compiled GDAL with the new ungeofied (GeoJP2=no) Jasper
library.
>> Then I tried to view my map. The server didn't give an Internal
>> Server Error this time! But a new problem is here. The images just
>> don't show up. I viewed the JPEG2000 images with "Image Viewer 2" in
>> Windows, and they appear just fine, so I know they are supposed to be
>> there. The layer used for tiling uses the same shapes as the TIFF
>> version did, so the Extent values should be proper.
> Brant,
> If you don't compile with the georeferencing enabled version of JasPer
> then your map won't work because GDAL won't know where your .jp2
> images are. The message that was causing the problem must be coming
> from somewhere in the GDAL JasPer driver or in the JasPer library
> itself. Just grep for it and strip it out and rebuild.
> > Maybe someone could test it out on their system. That way I can find
> out
> > if it is a server configuration problem, or a syntax problem.
> I downloaded the .map file and the jpeg2000 data and tested it on my
> system. It worked fine with "shp2img -m test.map -o out.png" once I
> had adjusted the SHAPEPATH, and set STATUS to DEFAULT in the layer in
> question.
> I also checked the .jp2 files and they look find with reasonable
> georeferencing.
> Note all my testing was with a Kakadu based version of GDAL, not using
> JasPer.
> Can you run gdalinfo on one of the .jp2 files yourself now that you
> have switched to the non-geo JasPer version? I think you will find
> the bounds and coordinate system are no longer known. Assuming that
> is true, you will really need to use the geo enabled version of JasPer
> and ensure that the debug message is removed.
> If you are using the most recent "geo-JasPer" version and you can't
> figure out how to get the problematic message out you should contact
> Andrey Kiselev (dron at remotesensing.org should get to him) about it.
> He maintains the JasPer driver in GDAL.
> Finally I would like to stress that the JasPer driver in GDAL has
> performance issues. It is very memory hungry for large images and is
> somewhat slower than Kakadu. Given the smallish size of your tiles
> you shouldn't have much problem with the memory use. In addition to
> the JasPer and Kakadu based GDAL JPEG2000 drivers, the new ECW SDK 3.0
> also supports JPEG2000 support and is free.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for
Rent
