jbox area
Arnold, Micheal B.
Micheal.Arnold at NSCORP.COM
Wed Dec 1 08:55:51 EST 2004
Thanks for the help Richard.
Here is the projection we are using:
PROJECTION
"proj=longlat"
"ellps=WGS84"
END
Would the constant used to determine the area change based on different UTM
zones?
Thanks again.
Mike Arnold
micheal.arnold at nscorp.com
-----Original Message-----
From: Richard Greenwood [mailto:richard.greenwood at gmail.com]
Sent: Tuesday, November 30, 2004 9:28 AM
To: Arnold, Micheal B.
Cc: mapserver-users at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] jbox area
jBox returns an area in screen pixels. You must convert it to sq feet,
sq meters, sq miles, or whatever you like. I wrote the above functions
to convert to sq feet and/or acres for a state plane coordinate system
in US Survey Feet. You need to modify them for your coordinate system,
resloution setting (if not 72), and desired output units.
Regards,
Richard Greenwood
www.greenwoodmap.com
On Mon, 29 Nov 2004 10:42:49 -0500, Arnold, Micheal B.
<micheal.arnold at nscorp.com> wrote:
> For some reason, the area that I am getting back for polygons using jbox
> seems to be off. The segment length and total length seem to be fine, but
> the area is off by a factor of about 5. Does anybody have any ideas or
> suggestions? Below are the measure_handler functions I am using.
> Thanks for the help!
> Mike Arnold
> function measure_handler(name, s, t, n, a)
> // c = 1 / 72dpi / 12inches_per_foot *
> 1.0003state_plane_scale_factor
> var c = 0.0011577546296296; // constant
> var f = [scale] * c; // scale factor
> if ((s>0) || (t>0))
> if (n < 3)
> defaultStatus = "This
> segment = " + distFormat(s*f) + ", Total = " + distFormat(t*f) + ", Number
> of vertices = " + n ;
> else
> of vertices = " + n + ", Area = " + distFormat(a*f) ;
> function roundFeet(x)
> var fpp = ([maxx] - [minx]) / [mapwidth]; // resolution
> (feet per pixel)
> if (fpp < 4) return (Math.round(x));
> if (fpp < 8) return (Math.round(x/5)*5);
> if (fpp < 17) return (Math.round(x/10)*10);
> if (fpp < 40) return (Math.round(x/25)*25);
> if (fpp < 80) return (Math.round(x/50)*50);
> return (Math.round(x/100)*100);
> function distFormat(x)
> var d;
> if (x > 7920) return ((Math.round(x/5280*10)/10) + " miles");
> d = roundFeet(x);
> if (d > 2640)
> return (d + " ft (" + (Math.round(x/5280*10)/10) + ")mile");
> return (d + " ft");
