MapServer 4.4.0 released
Vladimir Guzmán
bigfoot at MAIN-TASK.COM
Wed Dec 1 16:42:13 EST 2004
My configuration steps (In Fedora):
Hope that helps.
Vladimir Ilich Guzmán R.
http://maintask.com
wlx wrote:
>How to compile mapserver to make it as a apache DSO?
>>Steven Monai wrote:
>>>Hello,
>>>A quick question about the new v4.4.0 release:
>>>Scanning through the extensive changelog (wow, somebody's
>>been busy!),
>>>I see entries which lead me to hope that, with this version,
>>it might
>>>now be safe to use PHP/Mapscript with PHP loaded as an
>>apache module,
>>>rather than as an external CGI executable. Am I being overly
>>optimistic?
>>>Thanks,
>>>-SM
>>I've been using phpmapscript for 3 days or so, and everything
>>seems to work pretty well.
>>I'm working with:
>>Apache_1.3.33
>>php-5.0.2
>>mapserver-4.4.0-beta3
>>In fedora.
>>Php5 is compiled as an Apache DSO.
>>Best regards,
>>http://maintask.com
=> APACHE:
# wget http://apache.matrixau.net/httpd/apache_1.3.33.tar.gz
tar -xzvf apache_1.3.33.tar.gz
cd apache_1.3.33/
./configure --enable-module=so
make
make install
=> LIBPNG:
wget ftp://ftp.pbone.net/mirror/www-ccrma.stanford.edu/planetccrma/mirror/fedora/linux/core/updates/1/i386/libpng-devel-1.2.5-4.i386.rpm
rpm -Uvh libpng-devel-1.2.5-4.i386.rpm
=> LIBFREETYPE:
wget ftp://mirror.pacific.net.au/linux/redhat/redhat/linux/fedora/1/i386/os/Fedora/RPMS/freetype-devel-2.1.4-5.i386.rpm
rpm -Uvh freetype-devel-2.1.4-5.i386.rpm
=> LIBICONV:
wget http://ftp.gnu.org/pub/gnu/libiconv/libiconv-1.9.1.tar.gz
tar -xzvf libiconv-1.9.1.tar.gz
cd libiconv-1.9.1
./configure
make
make install
=> LIBJPEG:
wget ftp://mirror.pacific.net.au/linux/redhat/redhat/linux/fedora/1/i386/os/Fedora/RPMS/libjpeg-devel-6b-29.i386.rpm
rpm -Uvh libjpeg-devel-6b-29.i386.rpm
=> GD:
wget http://www.boutell.com/gd/http/gd-2.0.33.tar.gz
tar -xzvf gd-2.0.33.tar.gz
cd gd-2.0.33
./configure \
--without-xpm \
--with-jpeg=/usr \
--with-libiconv=/usr/local \
--with-freetype=/usr \
--with-zlib=/usr \
--with-png=/usr/local
make
make install
=> POSTGRESQL:
wget ftp://ftp3.ca.postgresql.org/pub/source/v7.4.6/postgresql-7.4.6.tar.bz2
tar -xjvf postgresql-7.4.6.tar.bz2
cd postgresql-7.4.6
./configure
make
make install
useradd -u 31 postgres
mkdir /home/postgres
chown postgres /home/postgres
mkdir /usr/local/pgsql/data
chown postgres /usr/local/pgsql/data
su - postgres
/usr/local/pgsql/bin/initdb -D /usr/local/pgsql/data
/usr/local/pgsql/bin/postmaster -D /usr/local/pgsql/data >logfile 2>&1 &
/usr/local/pgsql/bin/createdb test
/usr/local/pgsql/bin/psql test
exit
cp contrib/start-scripts/linux /etc/init.d/postgres
chmod u+x /etc/init.d/postgres
=> PROJ4:
wget ftp://ftp.remotesensing.org/pub/proj/proj-4.4.9.tar.gz
tar -xzvf proj-4.4.9.tar.gz
cd proj-4.4.9
./configure
make
make install
=> GEOS:
wget http://geos.refractions.net/geos-2.1.0.tar.bz2
tar -xjvf geos-2.1.0.tar.bz2
cd geos-2.1.0
./configure
make
make install
=> POSTGIS:
wget http://postgis.refractions.net/postgis-0.9.0.tar.gz
tar -xzvf postgis-0.9.0.tar.gz
mv postgis-0.9.0 postgresql-7.4.6/contrib/postgis
cd postgresql-7.4.6/contrib/postgis
vi Makefile
//Hay que buscar y cambiar la siguiente línea:
USE_GEOS=0
//Debe quedar:
USE_GEOS=1
make
make install
=> MYSQL:
wget http://dev.mysql.com/get/Downloads/MySQL-4.1/mysql-standard-4.1.7-pc-linux-i686.tar.gz/from/http://mysql.mirrored.ca/
tar -xzvf mysql-standard-4.1.7-pc-linux-i686.tar.gz
groupadd -g 33 mysql
useradd -u 33 -g mysql mysql
mv mysql-standard-4.1.7-pc-linux-i686 /usr/local/mysql
cd /usr/local/mysql
scripts/mysql_install_db
chown -R root .
chown -R mysql data
chgrp -R mysql .
bin/mysqld_safe --user=mysql &
bin/mysqladmin -u root password 'shizuka'
cp support-files/mysql.server /etc/init.d/mysql
=> PHP5 COMO MÓDULO DeL APACHE:
wget http://ca3.php.net/get/php-5.0.2.tar.bz2/from/this/mirror
tar -xjvf php-5.0.2.tar.bz2
cd php-5.0.2
./configure \
--with-config-file-path=/etc \
--with-gd=/usr/local \
--with-jpeg-dir=/usr \
--with-png-dir=/usr/local \
--with-freetype-dir=/usr \
--with-iconv-dir=/usr/local \
--with-zlib-dir=/usr \
--without-ttf \
--with-pgsql \
--with-mysql=/usr/local/mysql \
--with-regex=system \
--enable-dbase \
--enable-dbx \
--enable-versioning \
--enable-cli \
--with-apxs=/usr/local/apache/bin/apxs \
--enable-ftp
make
make install
make install-cli
=> GDAL:
wget http://gdal.org/dl/gdal-1.2.5.tar.gz
tar -xzvf gdal-1.2.5.tar.gz
cd gdal-1.2.5
./configure \
--with-geos \
--with-pg=/usr/local/pgsql/bin/pg_config \
--with-libz=/usr \
--with-png=/usr \
--with-jpeg=/usr
make
make install
=> MAPSERVER:
wget http://cvs.gis.umn.edu/dist/mapserver-4.4.0-beta3.tar.gz
tar -xzvf mapserver-4.4.0-beta3.tar.gz
cd mapserver-4.4.0-beta3
./configure \
--without-tiff \
--without-eppl \
--with-jpeg=/usr \
--with-threads \
--with-proj \
--with-gdal=/usr/local/bin \
--with-png=/usr \
--with-ogr \
--with-gdal \
--with-php=../php-5.0.2 \
--with-postgis=/usr/local/pgsql/bin/pg_config
make
cp mapscript/php3/php_mapscript.so /usr/local/php/extensions/
