Shapefile field problem
Abe Gillespie
agillesp at VT.EDU
Thu Dec 2 11:31:36 EST 2004
I certainly will as soon as I have the chance. I'm working on getting
this project out the door so I don't have much time right now. I've
encountered "problematic" fields in the past where when MapServer
encounters a problematic field it drops it and any fields after it.
What I have done is just deleted fields that gave me problems and then
the other "good" fields would show up. I thought it had to do with
NULLs in these fields. Now one of the problematic fields is one I need
to *use* ... so I can't exactly delete it. I can attach the files if
so desired. Is it ok to simply attach files and post to the group?
Are there any tools I can use to check the integrity of a shapefile
(and the shapes / records within said file)?
Thanks.
-Abe
On Dec 2, 2004, at 11:05 AM, Frank Warmerdam wrote:
> On Thu, 2 Dec 2004 11:19:01 -0500, Abe Gillespie <agillesp at vt.edu>
> wrote:
>> I used ogrinfo and it shows all the fields just fine. Specifically
>> I'm
>> trying to get a roads layer to work. I need to use the NAME field for
>> labeling and querying. But MapServer doesn't seem to recognize this
>> field (or any other fields past NAME). Oh, also, this is my MapServer
>> configuration:
>> MapServer version 4.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=WBMP
>> SUPPORTS=FREETYPE INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
> Abe,
> I don't know what is going wrong, but if you are keen to get a fix
> I would encourage you to try and reproduce the problem with 4.4,
> and if "successful" to report a detailed bug report along with
> the file, and everything needed to reproduce the problem. Also
> note the actual binaries you downloaded that resulted in the problem.
> I'm quite surprised by the problem you are encountering, but it doesn't
> sounds like it is really in my area. Hopefully Steve will pick up on
> it.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
