Shapefile field problem
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Thu Dec 2 11:41:09 EST 2004
This is interesting what are the field names? Any of them start with
numbers?
-e
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Abe Gillespie
Sent: Thursday, December 02, 2004 9:32 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Shapefile field problem
I certainly will as soon as I have the chance. I'm working on getting
this project out the door so I don't have much time right now. I've
encountered "problematic" fields in the past where when MapServer
encounters a problematic field it drops it and any fields after it. What
I have done is just deleted fields that gave me problems and then the
other "good" fields would show up. I thought it had to do with NULLs in
these fields. Now one of the problematic fields is one I need to *use*
... so I can't exactly delete it. I can attach the files if so desired.
Is it ok to simply attach files and post to the group?
Are there any tools I can use to check the integrity of a shapefile (and
the shapes / records within said file)?
Thanks.
-Abe
On Dec 2, 2004, at 11:05 AM, Frank Warmerdam wrote:
> On Thu, 2 Dec 2004 11:19:01 -0500, Abe Gillespie <agillesp at vt.edu>
> wrote:
>> I used ogrinfo and it shows all the fields just fine. Specifically
>> I'm trying to get a roads layer to work. I need to use the NAME
>> field for labeling and querying. But MapServer doesn't seem to
>> recognize this field (or any other fields past NAME). Oh, also, this
>> is my MapServer
>> configuration:
>> MapServer version 4.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=WBMP
>> SUPPORTS=FREETYPE INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
> Abe,
> I don't know what is going wrong, but if you are keen to get a fix I
> would encourage you to try and reproduce the problem with 4.4, and if
> "successful" to report a detailed bug report along with the file, and
> everything needed to reproduce the problem. Also note the actual
> binaries you downloaded that resulted in the problem.
> I'm quite surprised by the problem you are encountering, but it
> doesn't sounds like it is really in my area. Hopefully Steve will
> pick up on it.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for
Rent
