Shapefile field problem
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Thu Dec 2 12:15:52 EST 2004
Frank would know way more about this than me...but are any of the
Shapelib utilities (http://shapelib.maptools.org/) useful for you?
(shpdump, dbfdump)
jeff
Abe Gillespie wrote:
> Nope, all pretty standard like NAME, FULLADDR, etc. Nothing blatantly
> weird.
> -Abe
> On Dec 2, 2004, at 11:41 AM, Ethan Alpert wrote:
>> This is interesting what are the field names? Any of them start with
>> numbers?
>> -e
>> -----Original Message-----
>> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
>> On
>> Behalf Of Abe Gillespie
>> Sent: Thursday, December 02, 2004 9:32 AM
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: Re: [UMN_MAPSERVER-USERS] Shapefile field problem
>> I certainly will as soon as I have the chance. I'm working on getting
>> this project out the door so I don't have much time right now. I've
>> encountered "problematic" fields in the past where when MapServer
>> encounters a problematic field it drops it and any fields after it.
>> What
>> I have done is just deleted fields that gave me problems and then the
>> other "good" fields would show up. I thought it had to do with NULLs
>> in
>> these fields. Now one of the problematic fields is one I need to *use*
>> ... so I can't exactly delete it. I can attach the files if so
>> desired.
>> Is it ok to simply attach files and post to the group?
>> Are there any tools I can use to check the integrity of a shapefile
>> (and
>> the shapes / records within said file)?
>> Thanks.
>> -Abe
>> On Dec 2, 2004, at 11:05 AM, Frank Warmerdam wrote:
>>> On Thu, 2 Dec 2004 11:19:01 -0500, Abe Gillespie <agillesp at vt.edu>
>>> wrote:
>>>> I used ogrinfo and it shows all the fields just fine. Specifically
>>>> I'm trying to get a roads layer to work. I need to use the NAME
>>>> field for labeling and querying. But MapServer doesn't seem to
>>>> recognize this field (or any other fields past NAME). Oh, also, this
>>>> is my MapServer
>>>> configuration:
>>>> MapServer version 4.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=WBMP
>>>> SUPPORTS=FREETYPE INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
>>> Abe,
>>> I don't know what is going wrong, but if you are keen to get a fix I
>>> would encourage you to try and reproduce the problem with 4.4, and if
>>> "successful" to report a detailed bug report along with the file, and
>>> everything needed to reproduce the problem. Also note the actual
>>> binaries you downloaded that resulted in the problem.
>>> I'm quite surprised by the problem you are encountering, but it
>>> doesn't sounds like it is really in my area. Hopefully Steve will
>>> pick up on it.
>>> Best regards,
>>> I set the clouds in motion - turn up | Frank Warmerdam,
>>> warmerdam at pobox.com
>>> light and sound - activate the windows | http://pobox.com/~warmerdam
>>> and watch the world go round - Rush | Geospatial Programmer for
>> Rent
Jeff McKenna
GIS Specialist
DM Solutions Group Inc.
http://www.dmsolutions.ca
