[UMN_MAPSERVER-USERS] RE : [UMN_MAPSERVER-USERS] 4.4
Windows Binaries (Oracle, SDE, and others)
Fernando S.
simon at INF.UNIVALI.BR
Thu Dec 2 11:03:51 EST 2004
Hi Nicolas,
In this new version the connection string didn't changed.
This error didin't occured here, if you will look the source code
this message appear only when the mapserver didn't connected the Oracle.
So, are you tried with FastCGI support? How are you call the mapserver
(CGI)? Is it query mode?
Thanks.
Fernando Simon
Mapserver and Oracle Spatial developer
LCA - http://g10.cttmar.univali.br
Fortin,Nicolas [SteFoy] wrote:
>Hi Fernando,
>Thanks for your quick answer...
>I used the exact same mapfile I used for my previous version of mapserver. It worked fine with this previous version.
>Here's the mapserv-v output :
>MapServer version 4.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>If I point directly to mapserver on the server I got the normal:
>No query information to decode. QUERY_STRING not set.
>If I asked for a raster layer, I got it normally.
>It's only when I asked for an Oracle layer that I get the error message. (We use Oracle 9.2.0.4 and 10g)
>Either the message from my previous post or :
>Erreur CGI
>L'application CGI spécifiée a mal fonctionné en ne renvoyant pas de jeu complet d'en-têtes HTTP. Les en-têtes renvoyés sont :
>Do I have to change something in the mapfile!?
>Nicolas
