SLD Filter Using Default Mapfile Rendering
    Kralidis,Tom [Burlington]
    Tom.Kralidis at EC.GC.CA
    Thu Dec  2 17:06:45 PST 2004
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of John Fletcher
> Sent: Thursday, 02 December, 2004 17:54
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] SLD Filter Using Default
> Mapfile Rendering
> > What you could do is, if the data you're fetching is
> > available as OGC:WFS, is use MapServer as a WFS client and
> > apply the filter at the mapfile (or dynamically generated)
> > level and assume the same rendering as per mapfile.
> That's a really good idea - one I hadn't considered.  The
> only problem is that I need to be able to apply a filter
> dynamically through the CGI interface (I'm assuming Mapserver
> doesn't expose any CGI interface to access the filter for WFS layers).
The filter in the LAYER/METADATA object is set as:
"wfs_filter" "somefilterstring"
...which you could set via map_layername_wfs_filter (the developers can
confirm this -- I'm guessing this is allowed.
..Tom
> Has there ever been talk of the implementation of a
> DefaultSymbolizer in the SLD spec that would do this sort of
> thing?  I suppose the SLD spec could also just recommend a
> default action for a WMS to take if no Symbolizer is present.
>  Of course, I could just be exposing my ignorance of the
> whole subject...
> Thanks for the help.
> John
More information about the MapServer-users
