SLD Filter Using Default Mapfile Rendering
John Fletcher
jfletcher at LATITUDEGEO.COM
Thu Dec 2 17:54:26 EST 2004
> What you could do is, if the data you're fetching is
> available as OGC:WFS, is use MapServer as a WFS client and
> apply the filter at the mapfile (or dynamically generated)
> level and assume the same rendering as per mapfile.
That's a really good idea - one I hadn't considered. The only problem
is that I need to be able to apply a filter dynamically through the CGI
interface (I'm assuming Mapserver doesn't expose any CGI interface to
access the filter for WFS layers).
Has there ever been talk of the implementation of a DefaultSymbolizer in
the SLD spec that would do this sort of thing? I suppose the SLD spec
could also just recommend a default action for a WMS to take if no
Symbolizer is present. Of course, I could just be exposing my ignorance
of the whole subject...
Thanks for the help.
John
