SLD Filter Using Default Mapfile Rendering
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Thu Dec 2 13:37:08 EST 2004
In a nutshell, in OGC:WMS you can't get to Filter without SLD itself.
What you could do is, if the data you're fetching is available as
OGC:WFS, is use MapServer as a WFS client and apply the filter at the
mapfile (or dynamically generated) level and assume the same rendering
as per mapfile.
There's most certainly a few more ways to make this happen; the above is
using OGC approaches.
..Tom
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of John Fletcher
Sent: Thursday, 02 December, 2004 13:30
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] SLD Filter Using Default Mapfile
Rendering
Is there some way to filter the features drawn by Mapserver without
having to send rendering information in the SLD? Most times that I want
to filter features, the default rendering as set up in the mapfile is
sufficient, yet I am having to duplicate that rendering information
inside my SLD to get the features to show. I would like to just send a
Filter without any Symbolizer - it's the most tedious for layers with
many different scale or attribute dependent styles. I can't see
anything in the SLD spec about this, though it's a weighty document and
I may have missed it...
Thanks in advance,
John
