[UMN_MAPSERVER-USERS] CGI Error - 4.4 Windows Binaries
Howard Butler
hobu at IASTATE.EDU
Fri Dec 3 12:33:33 EST 2004
Nicolas,
A couple of thoughts. It could be very likely that my binaries are borked
with respect to Oracle Spatial. My binaries are *not* compiled with
FastCGI support, and Fernando might be able to comment more about its
current relationship to Oracle Spatial support. The cvs log shows a
significant change to maporaclespatial.c right at 4.4 beta 1. Things have
very likely changed significantly since the 4.3 binaries you were using
were made.
As for my binaries, I only really use the SDE support, which seems to be
working fine. My guess is that something is funky in my binaries, or
you've run into some sort of bug. Any chance you can use shp2img.exe to
test your mapfile and attach the msvc debugger to the process?
Howard
At 10:15 AM 12/3/2004, Fortin,Nicolas [SteFoy] wrote:
>Hi Fernando,
>I made more tests this morning with some wierd results:
>First, sometimes it works sometimes not, depending of either the zoom =
>level or the layers activated.
>If I ask for one oracle spatial layer, I got the error each time and =
>instantly.
>If I ask for an other type of layer than oracle spatial, all work fine.
>If I ask for mixed type of layers with oracle spatial included, it =
>become complicated...it seems that the order of the layers in the =
>mapfile have an effect; if the first layer found (and asked) in the =
>mapfile is oracle spatial, it get an error. If it's a raster or =
>something else, it works most of the time.
>I ran FileMon to see if this is a permission or file not found issue and =
>it's not.
>I checked IIS log file and when I get an error, the http status code is =
>502:
>2004-12-03 15:43:00 131.235.233.138 131.235.233.138 80 GET =
>/cgi-bin/mapserv.exe 502 0 391 -
>When this happens, the sc-bytes number is always 391
>I searched for the meaning of http 502 and found this from the w3c.org =
>website:
>Service temporarily overloaded 502 (TO BE DISCUSSED)=20
>The server cannot process the request due to a high load (whether HTTP =
>servicing or other requests). The implication is that this is a =
>temporary condition which maybe alleviated at other times.=20
>OR
>502 Bad Gateway
>The server, while acting as a gateway or proxy, received an invalid =
>response from the upstream server it accessed in attempting to fulfill =
>the request.=20
>First I thought that the reason is because my dev workstation is inside =
>our firewall and Oracle Database is outside...but I tested with an =
>Oracle database inside our firewall and the result is the same.
>When I shift to previous version (4.3 with oracle spatial downloaded =
>from maptools.org) all work fine.
>Now I'm lost...
>I download my binaries from Howard site at : =
>http://hobu.stat.iastate.edu/mapserver/
>Here's the mapserv -v result:
>MapServer version 4.4.0 OUTPUT=3DGIF OUTPUT=3DPNG OUTPUT=3DJPEG =
>OUTPUT=3DPDF OUTPUT=3DSWF SUPPORTS=3DPROJ SUPPORTS=3DFREETYPE =
>SUPPORTS=3DWMS_SERVER SUPPORTS=3DWMS_CLIENT SUPPORTS=3DWFS_SERVER =
>SUPPORTS=3DWFS_CLIENT SUPPORTS=3DWCS_SERVER INPUT=3DPOSTGIS =
>INPUT=3DORACLESPATIAL INPUT=3DOGR INPUT=3DGDAL INPUT=3DSHAPEFILE
>How could you have such a complete log from mapserver ? When I got the =
>error, I have no line add to my mapserver log...
>I'm on Windows 2000 SP4 with IIS 5.0
>Thank you very much for your help Fernando. If someone other than =
>Fernando has any idea of what I could do to find the solution, you're =
>welcome!
>Nicolas
