Given map extent is invalid
Frank Warmerdam
fwarmerdam at GMAIL.COM
Fri Dec 3 20:11:29 EST 2004
On Fri, 3 Dec 2004 16:15:40 -0600, Dan Liu <dan.liu at state.mn.us> wrote:
> Hi,
> PHP mapscript application which worked in mapserv 4.2.5 now gives the error
> 'Given map extent is invalid.' after function 'ms_newMapObj()' is called.
> The extent is
> EXTENT 118109 5269319 792271 4997508
> Does anybody know want is wrong? Any help is appreciated.
Dan,
The arguments to EXTENT are xmin, ymin, xmax, ymax.
But your "ymax" value is smaller than your "ymin" value.
MapServer 4.4 does more extent validation then used to be done.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
