multiple join {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Fri Dec 3 18:42:18 EST 2004
I have created an ogr data source to connect a shape file to an ODBC
table. It works, but I was not able to create class expressions based
on a column of the joined table. Do I need special column names to
use the joined columns, eg. other than [column_name]?
Part of my map file
LAYER
NAME xxx
CONNECTIONTYPE OGR
CONNECTION "base/kafold.shp"
DATA "SELECT * FROM kafold LEFT JOIN 'ODBC:epeng'.ms_ugy on kafold.hrsz=ms_ugy.hrsz"
TYPE POLYGON
STATUS DEFAULT
CLASS
EXPRESSION ([case_id] = 2)
STYLE
COLOR 100 100 100
END
END
CLASS
EXPRESSION ([case_id] = 4)
STYLE
COLOR 0 255 0
END
END
END
These classes don't work, case_id is a column from joined table.
Tanks
Zoltan
