jbox and panning
Richard Greenwood
richard.greenwood at GMAIL.COM
Sat Dec 4 10:05:59 EST 2004
On Fri, 3 Dec 2004 14:23:49 -0500, Arnold, Micheal B.
<Micheal.Arnold at nscorp.com> wrote:
> Has anybody ever had a problem like this:
> I have implemented image swapping with jBox. When I try panning, everything
> works fine the first time I move my map. The second (and subsequent)
> attempts fail. When I try to pan, the map jumps to what seems like a random
> place. I am having similar problems trying to zoom in on my map.
> It seems like the problem might be with imgxy or imgbox, but I can't figure
> out where the disconnect is. I am not sure if something needs to be reset
> since I am not re-submitting the page.
> Can anybody offer any suggestions?
> Thanks,
> Mike Arnold
> micheal.arnold at nscorp.com
Each time you swap images, you are chaning your map extents. Are you
keeping track of that on the client? When you request a whole new pae,
mapserver calculates the new map extent and usually you save that in
hidden variables on the page. Then use that extent, combined with
user-input pixels coordinates to request the next map.
However, when you image swap, you need to calculate and keep track of
the map extent on the client side.
Regards,
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
